I am trying to Port Foward port 8080 to LAN address 192.68.0.8
NeilD
I am trying to Port Forward port 8080 to LAN address 192.68.0.8 through router WAN IP 71.208.68.64. I used NAT settings on my Z3510XZ router to add a port forwarding rule to allow any Internet IP to access the server via port 8080. This is not working I tried telnet 71.208.68.64 8080 and tested. But telnet 71.208.68.64 80 and telnet 71.208.68.64 443 are working.. So, some thing is blocking the access to 8080. Can some one help with a solution.
Hi Sir,
sometime the server maybe used the port 8080 to do some service so the Port Forward when you setup, if possible you can change the port and try to test again ? if still have problem, please contact your ISP.0
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
