signal strength not showing up
Hi there
I use Nebula to configure my wifi-environment where there are 4 APs. Recently I noticed that the signal strength of some (but not all) clients connected to the AP called AP-Stube are not showing up. clients connected to the other APs are showing the signal strength.
could you please have a look at my site (Dietikon, Org Graf) ? I restarted the AP-Stube several times and also could not find any solution in the community.
Many thanks for your support
Kind regards
Andrew
Hi @Wookie,
After checking, we would like to exclude this issue from being related to AP. Could you help to reboot your AP "AP-stube"?
Zyxel Melen0
Hi @Wookie,
Thanks for the privilege.
I have checked the AP-Stube's current stations and it displays the lacking information like signal strength, client channel, etc. But somehow the AP client page did not display.
We are checking on it and I will update you once I get further information.
Zyxel Melen0 -
thats great, thanks a lot.
Hi @Wookie,
Zyxel Melen0 -
strange, I actually restarted AP-Stube several times and now the issue seems to be gone. thanks for your support
- 441 Beta Program
- 533 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
