Deactivating IPSec VPN Client from a pc (to use it in another machine)
Hi, I have an issue with IPSec VPN Client activated with the serial key on a pc.
I'd like to deactivate it, but I can't uninstall it manually, because I can't have the physical pc at hand.
What I basically would like to do is to deactivate said license key in the vpn software on a certain pc, and then in the future, use the same license key on another machine.
Thank you very much in advance for the help.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    edited June 2024 Answer ✓
    Hi @alse93,
    To help you find the method, could you DM me the license key for me to check? We will check if the license key can be deactivated on our side and if yes, we will help to deactivate it.
    Zyxel Melen
  • Zyxel_Melen
    Hi @alse93,
    Zyxel Melen
  • Zyxel_Melen
    Hi @alse93,
    Thanks for DM me. The process is done. Please help to verify.
    Zyxel Melen
Service & License Help Center
