AP & mac address filtering ??
ITGS
ITGS Posts: 2 image  Freshman Member
I installed 3 new NWA50AX in a new site and all work fine.
I would limit access on a specific SSID , based on device mac address but I don't undersand how can I do ??
Thank you for support
  • Zyxel_Jay
    Zyxel_Jay Posts: 226 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    edited May 2022 Answer ✓
    Hi @ITGS
    Welcome Zyxel Community
    Here is a FAQ for your reference.
    [NEBULA] How to configure MAC-based authentication to enhance Wi-Fi security?
    Please note that when you are setting the SSID Advanced Settings, select the SSID you need for mac auth.
    You also use this FAQ
    [NEBULA] How to add policy rules for clients?
    Select "to specific SSID" and manage your device allow or block.
    Any problem can talk to us.
    Thank you, have a good day.
    Zyxel_Jay
  • ITGS
    Thank you for reply.
    Unfortunately I can't enable mac authentication. Option is grayed out.
    I think that NWA50AX don't support this feature...
    If this is the reason, I'm very surprise because it's a standard feature and is very limiting.
    If I knew this, I did not buy this AP
    PeterUK Posts: 4,427 image  Guru Member
    in Standalone you should have mac address filtering for that model not sure why you can't in NEBULA
  • Zyxel_Jay
    @ITGS @PeterUK
    Thanks for your reply. Sorry for not noticing this.NWA50AX isn't supported MAC Authentication.
    You can find this information with the path.HELP>DEVICE FUNCTION TABLE>SB Access Point
    Nebula has the same mechanism as Mac address filtering, which you can set up using the second hyperlink from the previous article.
    “You also use this FAQ
    Select "to specific SSID" and manage your device allow or block. “
    If you have any question,please reply me.
    thank you
    Zyxel_Jay
  • kevindd992002
    kevindd992002 Posts: 36 image  Freshman Member
    What happens if you add the device to the MAC list and set Authorized to No?
Nebula Tips & Tricks
