Update firmware
Hello
i see that there are a new firmware 1.20(ABXF.2)C0
But when i login in myzyxel i don't see the model (USG FLEX 100H) and firmware
Where can i download the new firmware?
Hi @Gru_Ma,
The device becomes unreachable if you upgrade USG FLEX H directly from factory default version to 1.20 or later firmware version directly. That's why the official firmware is unavailable on myZyxel.com.
Is the firmware version of your USG FLEX H 1.10 or 1.10 based date firmware? If so, I will send the version 1.20 to you in private message. Sorry for the inconvenience.
You have to download on the FLEX
starting to think this is a Zyxel move to not let use download a .bin file anymore🤐
Which is a mistake, because I HATE cloud-connected products, which are all a dumb idea in terms of security, especially in a firewall. If I wanted cloud connected crap I would buy Meraki
Hi @Gru_Ma,
- 441 Beta Program
- 292 Service & License
