LTE3202_M430 Vulnerabilities Firmware
I've just bought a used LTE3202_M430 router (Ortel mobile was original the SIM provider) to provide an internet access point to my solar inverter via LAN cable. Current firmware version is V1.00(ABNH.2)C0. I tried flashing the latest firmware from LTE3202_M437 V1.00(ABWF.3)C0, but unsuccessfully.
The router only connects to the cloud service of the solar inverter. Do you see any security risks with this limited usage using the currently installed firmware?
Please, can you send me the latest working firmware for my device. You can use my Email.
I tried registering my device (SN+MAC) but there was an error "device not found"
  • Friday
    Friday Posts: 114  Ally Member
    LTE3202-M430 and LTE3202-M437 is using a different fw, which is not compatible.
    The latest fw for LTE3202-M430 is your current fw-V1.00(ABNH.2)C0.
  • Friday
