GS1920-24 cant boot up, cant restore to factory
Hi, i have a GS1920-24 which start blink sys led when i powered it, during start up all port led is up in red and green then off. After about 1 minute sys led turn off, and nothing work. i tried press and hold reset button at side but nothing happend.
Here is picture of board and video of startup progress:
Hi @trungthanh1288,
Please try to factory default your switch with the below post first.
I will DM the console port position and the type of console cable to you. Then you can factory default this switch.
Here is the file that include the firmware and ROM file for factory default:
Zyxel Melen0 -
I have exactly the same issue with my GS1920-24. After a reset and leaving it powered on overnight, it still won’t boot up or become reachable.I would appreciate any help or advice.
Thank you!
Hi @mkndroid,
This could be firmware issue or hardware issue. Please check if your switch has a 4-pin console port in the left of your switch. If it has it, please referece this FAQ to connect the 4-pin console.
How to use the 4 pin console to connect to Zyxel switch? — Zyxel CommunityAnd this post to recover firmware (configuration part is not necessary):
If firmware recovery does not help, this could be a hardware issue. Please reference this FAQ to submit a RMA request.
In addition, if you didn't find the 4-pin console port, this means your switch is older version of GS1920, which is end-of-life for a long time before. Please consider to purchase a new GS1920-24.
Zyxel Melen0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 457 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
