Zyxel Nebula Access points connection issues
We have a customer with some issues with wifi. we have installed 4 Access points.
the issue is very low throughput. speedtest gives us 0.4Mbit/s
And to be honest i have limited understanding at the moment about wifi, so i want to start with some basic questions. When i look in nebula, to the clients, i see the TX rate and RX rate values. some are low (arround 24, but others are highter then 200).
should it be low or high?
i hope to hear from you.
thx.
Dennis
this issue seems to be solved
Hi @Dpj,
This is more likely because the signal strength is low. The low signal strength will cause the wireless link speed to became low as you encountered.
Could you help to enable Zyxel support for us to check?
Also, could you help to provide some issued MAC addresses to me?
Zyxel Melen0 -
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 431 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
