NAS326
adent
adent Posts: 1
edited June 2024 in Personal Cloud Storage
Hi, I can not login to my nas after yesterday update. Access denied. Any suggestions ? Best regards from Warszawa.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    It is possible that an update has disabled certain characters (like ; ' & | and some more) in the password. If you had these before the update, you can no longer login, as they are filtered away. The only solution is to reset the password. (Press the reset button until it beeps once).
