NAS542 resync loop
NAS542, 4 drives, Raid5, no spare, Firmware V5.21(ABAG.14)
For some time now, my NAS542 has been resynchronizing almost constantly. smartctl shows no errors on the 4 drives, mdadm --examine /dev/sd[abcd]3 also shows nothing unusual. Where can I find the trigger?
So what did 'mdadm --examine /dev/sd[abcd]3' say? And is it always the same disk which is resyncing?
~ # mdadm --examine /dev/sd[abcd]3
/dev/sda3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 33f5a2f7:c031c1a9:bb1e6599:b560f407
Name : NAS542:2 (local to host NAS542)
Creation Time : Thu May 6 14:47:18 2021
Raid Level : raid5
Raid Devices : 4Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB)
Array Size : 5848151040 (5577.23 GiB 5988.51 GB)
Data Offset : 262144 sectors
Super Offset : 8 sectors
State : active
Device UUID : c5bb5b9e:4b700eb4:87f8ed8f:5b0c2c65Update Time : Sat Jun 22 16:34:55 2024 Checksum : 3293770e - correct Events : 9712 Layout : left-symmetric Chunk Size : 64K
Device Role : Active device 0
Array State : AAAA ('A' == active, '.' == missing)
/dev/sdb3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
State : active
Device UUID : b855ccea:2ba8de64:083c3d9c:06b381c7Update Time : Sat Jun 22 16:34:55 2024 Checksum : 9e79330c - correct Events : 9712 Layout : left-symmetric Chunk Size : 64K
Device Role : Active device 1
/dev/sdc3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
State : active
Device UUID : efe096ae:ddcd3574:1bc65cf5:882d53f9Update Time : Sat Jun 22 16:34:55 2024 Checksum : fc8be88c - correct Events : 9712 Layout : left-symmetric Chunk Size : 64K
Device Role : Active device 2
/dev/sdd3:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Raid Level : raid5
State : active
Device UUID : e7d4bbc6:1c2f01fb:32078fd9:9c644feaUpdate Time : Sat Jun 22 16:34:55 2024 Checksum : 70aab5f0 - correct Events : 9712 Layout : left-symmetric Chunk Size : 64K
Device Role : Active device 3
Array State : AAAA ('A' == active, '.' == missing)>And is it always the same disk which is resyncing?
Volume1
smartctl -x all drives
drive sdb: "SCT Error Recovery Control command not supported"
I will replace the disk
may it help…0 -
Did you get that 'mdadm —examine' while it was resyncing? In that case it should have been visible. How much time does a resync take? Could it be that it's the firmware partition array (2GB) which is resyncing?
You can get more info from
cat /proc/mdstat
which gives the array, the rebuild status and the exact member which is resycing.
around 20h
I have stopped all jobs that write to the nas.
we'll see tomorrow, in the meantime 2 disks are already complaining.
I will swap them when resync is hopefully done.~ # cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : active raid5 sda3[5] sdb3[4] sdd3[7] sdc3[6]
5848151040 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [U_UU]
[>....................] recovery = 0.1% (2254316/1949383680) finish=3311.6min speed=9799K/secmd1 : active raid1 sda2[5] sdd2[7] sdc2[6] sdb2[4]
1998784 blocks super 1.2 [4/4] [UUUU]md0 : active raid1 sda1[5] sdd1[7] sdc1[6] sdb1[4]
1997760 blocks super 1.2 [4/4] [UUUU]unused devices: <none>
fck. 2 drives died. after replacement it's ok.
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
