VOIP/SIP Best Practice For Ports
Pook
Pook Posts: 153 image  Master Member
First Comment First Answer Friend Collector Sixth Anniversary
Hi Guys
Can anyone advise best practice for making sure all required ports are open for cloud hosted handsets? Obviously this is not a NAT rule so that leaves using the security policy section for allowing the ports and IP addresses of the service provider.
Really appreciate any feedback as to what others are doing, we are using Callswitch.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,726 image  Zyxel Employee
    Hi @Pook ,
    If your SIP server supports the SIP over NAT scenario, please go to Configure > Firewall > Firewall Setting > SIP ALG to enable SIP ALG and implement the configuration.
    Note
    SIP Signaling Port: If you are using a custom UDP port number (not 5060) for SIP traffic, enter it here.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @Pook ,
    Could you please let us know which model you want to configure for VoIP/SIP?
    Zyxel_Judy
  • Pook
    That would nelp, USG/ATP Flex Series using Nebula Cloud please.
  • Zyxel_Judy
    Hi @Pook ,
    Note
    Zyxel_Judy
Nebula Tips & Tricks
