Ability to block devices from connecting to SSID in Nebula
It would be great if I could prevent entire groups of devices (e.g. iPhone, Android, iPad) from connecting to certain SSIDs.
For example blocking cell phones from connecting to the main SSID and allowing them on the Guest wireless.
Hi @Arvee
There is a feature in our Nebula Control Center (NCC) that allows users to configure a "Block list" within the Client Policy settings to prevent specific devices from accessing certain SSIDs. To use this feature, you need to gather the MAC addresses of the devices you want to block and add them to the rule. For more detailed guidance, you can refer to this article:
Does this feature meet your needs?
Kay
Hi Kay,
Not exactly. I was hoping for a feature to block entire category of devices from a certain SSID without having to explicitly block them once their exact MAC address is known.
Specifically I want to block people's mobile devices from the main network SSID while allowing them on a guest SSID. This list of devices changes far too often to rely on looking through a list of devices connected and manually adding them to a block list.
Following…
- 603 USG FLEX H Series
- 481 News and Release
