No System/Security Logs on premise on 5G router linked to Nebula
GiuseppeR
GiuseppeR Posts: 682 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited July 2024 in Nebula
Hello everyone,
I cannot see logs when I remotely connect to indoor/outdoor 5G router managed by Nebula.
Below you can see the error:
  • Zyxel_Kay
    Hi @GiuseppeR
    As discussed in our private message, the issue you're experiencing is related to the browser.
    If anyone else encounters a similar problem, please try the following steps:
    1. Upgrade your browser to the latest version.
    2. Clear your browser cache.
    3. Disable any browser extensions.
    These steps should help resolve the issue.
    Kay
  • Zyxel_Kay
    Hi @GiuseppeR
    To gain a clearer understanding of your issue, could you please enable Zyxel Support on your Nebula Control Center (CC) and provide us with your organization and site name? This will help us look into your devices directly.
    Thank you.
    Kay
  • GiuseppeR
    Hi @Zyxel_Kay
    you have a PM with details about that request. See you soon
  • Zyxel_Kay
    Hi @GiuseppeR
    Thanks for sharing the information via PM.
    Upon reviewing your site and testing the 💎 Remote configuration tool on your Nebula device, we noticed that the System/Security log appears normally. For more details, please refer to the attached video in the PM.
    Could you please try again and check if the issue persists on your end? If it does, please help us by providing a screen recording using this tool: https://jam.dev/s .
    Thank you.
    Kay
  • Zyxel_Kay
    Hi @GiuseppeR
    Kay
Nebula Tips & Tricks
