Schedule reboot option for devices inside Nebula
GiuseppeR
GiuseppeR Posts: 430  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited July 2024 in Nebula
Hello everyone,
is there a way to schedule reboots for appliances inside Nebula?
If I look into firewalls, switches and other devices I can see "Reboot" button but with no choice of scheduling it.
For example: I want that some Security Routers tha I have on the field go for a reboot once a month. Like DCS channel search you can schedule if you want.
Is there a way to do that or it is a missing feature to add to Nebula Ideas section?
Nebula Tips & Tricks
