Zyxel Nebula Access points connection issues
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
We have a customer with some issues with wifi. we have installed 4 Access points.
the issue is very low throughput. speedtest gives us 0.4Mbit/s
And to be honest i have limited understanding at the moment about wifi, so i want to start with some basic questions. When i look in nebula, to the clients, i see the TX rate and RX rate values. some are low (arround 24, but others are highter then 200).
should it be low or high?
i hope to hear from you.
thx.
Dennis
  • Dpj
    this issue seems to be solved
