Static IP adrress reservation on USGFLEX 200H
2»
    PeterUK Posts: 4,446 image  Guru Member
    edited July 2024
    Our client still obtains the IP address even if the client's name entered in the DHCP table list (e.g., Client_A) is different from the actual client's name (e.g., DESKTOP-JUDY).
    That not what I'm seeing
    No DHCP offer wrong name
    DHCP with right name
    Update 2
    With more testing the problem is using underscore "_" in name which cause the DHCP to fail completely
    Update 3
    If a computer is named underscore "_" you it will get a IP from the DHCP server but if you reserved it in the table it fails to get its IP and causes other computers to fail to get a IP by DHCP
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    Hi @PeterUK ,
    Thank you for providing your file and feedback. We were able to reproduce the issue when the client's name is set as an underscore (_) or other special characters.
    We will contact you with any updates.
    Zyxel_Judy
    Untitled Image
  • AlexandervonW
    AlexandervonW Posts: 17 image  Freshman Member
    Hi PeterUK,
    many thanks for digging into that. Would i be 30 years younger, i would/could have helped you. ;)
    Meanwhile i have switched back to a ATP500 and all is fine there.
    Have a nice day
    Alexander
  • Zyxel_Judy
    Hi @PeterUK ,
    The issue of being unable to add an entry to the IP/MAC binding list when the name begins with "_" will be addressed in a future firmware update. Please follow the Security Appliance News & Releases section for updates on enhancements and fixes.
    Zyxel_Judy
    Untitled Image
