NWA50AX: Extending existing WLAN over ethernet
Dear @angelo5432,
Welcome to Zyxel Community!
It should be feasible to create a same SSID and credentials (security mode/password) as your existing WLAN in the NWA50AX model to do auto-connect between APs (unless there’s invalid setting that is not able to be configured in the NWA50AX, e.g., the length of SSID name is more than 32 characters).
You may refer to the following steps to configure SSID names and credentials on the Nebula:
1. Go to Nebula > Access point > SSID settings.
Under simple mode, it can easily add a SSID, and configure the name and credentials of the SSID.
2. After creating the SSID, you can disable Simple mode, then click “Edit” to make changes of the SSID settings with more options.
3. On SSID settings page, you can configure the security mode and password.
After finishing, please click “Back”.
4. Click “Save” to save the configuration.
If there are further questions, please let us know.
Thank you.
Regards,
Nathan
Dear @angelo5432,
Thank you.
Regards,
Nathan
Thank you very much Nathan.It just works very nicely!In the end, the solution was much easier than I imagined 😉
Helllo,
l would also like to use my NWA50AX to extend my existing WLAN over ethernet so i don't have to manually switch to a different WiFi when I switch rooms. I tried using the instructions you provided above but I think you have changed the interface of the dashboard so the screenshots no longer correspond. Could you provide me with a new explanation with updates screenshots?
I also have a question: am I supposed to create a new SSID network on the NWA50AX that has the same wifi name and password as my existing wifi that comes from the router? I didn't really understand your explanation on than point. I currently have my existing wifi from the router (lets call that wifi1 ) and wifi from the NWA50AX running (lets call that wifi2). How do I mearge it together? It would be helpful if you provide an explanation for dummies with updates screenshots. Thanks in advance.
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
