Schedule reboot option for devices inside Nebula
Hello everyone,
is there a way to schedule reboots for appliances inside Nebula?
If I look into firewalls, switches and other devices I can see "Reboot" button but with no choice of scheduling it.
For example: I want that some Security Routers tha I have on the field go for a reboot once a month. Like DCS channel search you can schedule if you want.
Is there a way to do that or it is a missing feature to add to Nebula Ideas section?
Hi @GiuseppeR ,
Currently, there is a reboot schedule available for AP and mobile routers. For detailed information, please refer to the following articles:
Zyxel_Judy
Hi @GiuseppeR,
There's no schedule reboot feature for the Security Router on Nebula currently. Could you share why you need schedule reboot fuction for the Security Router?
Zyxel Melen0 -
Hello @Zyxel_Melen
this was a wider request regarding all of Zyxel products, to be specific with security routers I saw better performance after a reboot (like in the Case240700129).
Is there a chance to see "Schedule Reboot" option inside Nebula?
Have a nice day, best regards
Hi @GiuseppeR ,
Zyxel_Judy
Hello @Zyxel_Judy
I saw that option under APs panel.
I tried to find that option also on NR7101 and NR5101 that I have on the field. I'm unable to see that.
I see that "Maintenance" option only on a brand spanking new FWA505 that I installed recently.
Is that correct?
Hi @GiuseppeR ,
You're right. The maintenance feature is only supported by the successors of the NR5101 and NR7101, such as the FWA710, FWA510, and FWA505.
Zyxel_Judy
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
