NR7102 – how to access from behind UDM SE?
hi there,
just deployed a NR7102. I am using it in IPPT mode and it seems to work fine as a second WAN on the UDM SE even though the connection ist not stable despite very good 5G reception. Any ideas on how to fix this? The UDM SE seems to lose the WAN connection every few seconds. No clue as to why this should be the case…
Now I was trying to access the NR7102 interface from behind the UDM SE via the internal network. I tried using this guide: NR7101 / FWA710 - So stellen Sie den Bridge-Modus ein (mobiles IP-Passthrough) but unfortunately failed so far.
I used the following port forwarding rule within the UDM SE with WAN2 being the Zyxel NR7102:
Unfortunately trying to access from internal LAN via http://192.168.2.1:20080 won´t do the trick. Internal IP addresses distributed via DHCP from the UDM SE are from the 192.168.1.1 range…
Where is my error in trying this?
cheers,
JohnnyT76
No ideas on how to configure the UDM SE and subsequently the NR7102 in order to access the GUI from the internal LAN while running it in bridge mode?
Cheers,
JohnnyT
If Internal IP addresses distributed via DHCP from the UDM SE are from the 192.168.1.1
Have you tried
http://192.168.1.1:20080
Also please check the MGMT setting for IPPT.
Hi there,
thanks for coming back to me.
http://192.168.1.1:20080didn't work, which somehow makes sense since 192.168.1.1 is the IP address of the UDM SE. According to the document the Zyxel should be reachable via LAN in bridge mode via 192.168.2.1 which also does not work.
The settings for the bridge are as follows (accessed via wlan):
No clue what is wrong there.
JohnnyT
What is the gate way IP of UDM SE
EX: UDM SE 192.168.22.62 and it's gate way IP is 192.168.22.61
You can try http://192.168.22.61
Because you mark the IP it is start with 10.240.8….
You can find the gate way IP of this IP
Nope the UDM SE gateway IP is 192.168.1.1
With WAN2 being the Zyxel in bridge mode.
JohnnyT
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
