NR7102 – how to access from behind UDM SE?
JohnnyT76
JohnnyT76 Posts: 7 image  Freshman Member
edited June 2024 in Mobile Broadband
hi there,
just deployed a NR7102. I am using it in IPPT mode and it seems to work fine as a second WAN on the UDM SE even though the connection ist not stable despite very good 5G reception. Any ideas on how to fix this? The UDM SE seems to lose the WAN connection every few seconds. No clue as to why this should be the case…
Now I was trying to access the NR7102 interface from behind the UDM SE via the internal network. I tried using this guide: NR7101 / FWA710 - So stellen Sie den Bridge-Modus ein (mobiles IP-Passthrough) but unfortunately failed so far.
I used the following port forwarding rule within the UDM SE with WAN2 being the Zyxel NR7102:
Unfortunately trying to access from internal LAN via http://192.168.2.1:20080 won´t do the trick. Internal IP addresses distributed via DHCP from the UDM SE are from the 192.168.1.1 range…
Where is my error in trying this?
cheers,
JohnnyT76
  • JohnnyT76
    No ideas on how to configure the UDM SE and subsequently the NR7102 in order to access the GUI from the internal LAN while running it in bridge mode?
    Cheers,
    JohnnyT
  • Internetheavyuser
    Internetheavyuser Posts: 96 image  Ally Member
    If Internal IP addresses distributed via DHCP from the UDM SE are from the 192.168.1.1
    Have you tried
    http://192.168.1.1:20080
    Also please check the MGMT setting for IPPT.
  • JohnnyT76
    Hi there,
    thanks for coming back to me.
    http://192.168.1.1:20080didn't work, which somehow makes sense since 192.168.1.1 is the IP address of the UDM SE. According to the document the Zyxel should be reachable via LAN in bridge mode via 192.168.2.1 which also does not work.
    The settings for the bridge are as follows (accessed via wlan):
    Screenshot_20240719-073109.png Screenshot_20240719-073029.png Screenshot_20240719-073013.png Screenshot_20240719-072940.png Screenshot_20240719-072858-EDIT.jpg
    No clue what is wrong there.
    JohnnyT
  • Internetheavyuser
    What is the gate way IP of UDM SE
    EX: UDM SE 192.168.22.62 and it's gate way IP is 192.168.22.61
    You can try http://192.168.22.61
    Because you mark the IP it is start with 10.240.8….
    You can find the gate way IP of this IP
  • JohnnyT76
    Nope the UDM SE gateway IP is 192.168.1.1
    With WAN2 being the Zyxel in bridge mode.
    JohnnyT
