FWA510 WPS disabled but light still on
SJDC
SJDC Posts: 2 image  Freshman Member
I have disabled WPS for both 2.4 and 5G but the light stays on - should this not grey out? The light is very annoying and I never use WPS. Any help appreciated.
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    In the router settings is there a Network Settings>Wireless>WPS section?
    Can you see an enable WPS setting that you can disable there?
    Otherwise i think you also need to turn off wifi!
  • SJDC
    Thanks for your reply.
    It is set to off and on both channels (I found you had to select each channel individually in the General tab and go turn WPS off).
    It does say in Note 2 there that "The WPS button will gray out when wireless LAN or WPS is disabled", OR being the key word. But maybe as you say, wireless needs to be turned off too which is not practical for me. Such a shame you can't control a simple light!
  • UnifiMan
    UnifiMan Posts: 1 image  Freshman Member
    I came here for the same problem. Even with the latest firmware this is still a problem. Impossible to turn off the strong, green light. Does not exactly blend in at our mountain cabin from 1966., I'll have to put some tape over it. Ridiculous.
  • emreoez
    emreoez Posts: 22 image  Freshman Member
    Zyxel Team
    Any news on the ability to turn that LED off?
    Very anoying that it's possible on Access Points but not on this FWA Router..
