NR7101 Signal Information Table values?
Hi, I'm trying to pointing the NR7101 modem at the base station as best as possible.
I logged into the GUI page / System Monitor > Cellular info.
Signal Information Table:
What do these different columns mean? "LTE PCC", "SCC #1", "SCC #2 and "NR PCC"
Hi Tapani,
In networks which support LTE Advanced and 5G-NSA, NR7101's connection does not only rely on 1 band but several bands.
LTE PCC is LTE Primary Component Carrier, it will be the 1st band your NR7101 connect to the network. NR7101 can receive downlink and send uplink traffic through this band.
LTE SCC is LTE Secondary Component Carrier, there could be more than 1 LTE SCC in your connection. NR7101's downlink traffic can be boosted by adding SCCs.
NR PCC is NR Primary Component Carrier, it is the 1st NR band your NR7101 connects to.
Regards,
Bob
Hi Tapani,
Regards,
Bob
Thanks for the information!
Are any of these the same as the ZyxelAir App RSRP value, or is the ZyxelAir App RSRP value generated somehow differently?
Regards, Tapani
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
