NWA50AX - Set up a 2.4 GHz wi-fi network
Hi @ClaudioLessa,
Thank you for reaching out about setting up your Zyxel NWA50AX AP. Let's go through this process step-by-step:
First, let's address the issues:
- The SSID "Zyxel-6C7C" should be the SSID of your NWA50AX. Please check the MAC address on the bottom label of the device to see if the last 4 digits are 6C7C.
- After ensuring that your Mac device connects to this SSID, enter 1.1.1.1 in the browser to access the web GUI.
⇒ Above is the step to configure the NWA50AX on its web GUI.
However, you may opt for cloud management using Nebula, which is more convenient. Here is a guideline on how to register the AP on Nebula Cloud Center (NCC):
After successfully registering the AP on NCC, please follow the FAQ below to configure the 2.4 GHz network for NWA50AX.
Please let us know if there are any further concerns.
Nami
Hi @ClaudioLessa,
Nami
Nami
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 439 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 91 Security Highlight
