ZYXEL - INTERNET ACCESS DX3301-T0-EU02V1F WIFI 6 AX1800 VDSL2
hi my apple I pad will not connect on WIFI.
all my other devices can
it say unable to access
I done the following to try to fix the problem
reset the I pad network setting
rest the settings on the I pad
made a guest network just for the i pad with the 5 GHz turn off
restart the router
took to my friend house and it connect first time to there WIFI
any help would be more than welcome
thanks
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    Maybe try to upgrade IPAD software, or change wifi security to WPA2 or disable password to see.
