PHP-MySQL-phpMyAdmin stuck at 45%
lee626
lee626 Posts: 5 image  Freshman Member
edited July 2024 in Personal Cloud Storage
I've fixed the missing apps on my NAS520 thanks to Mijzelf, however when I try to install PHP it gets stuck at 45%. When trying to apply the solution of editing the ZYPKGS file through WinSCP I am met with the following issues.
2. Secondly when I try to disconnect from the internet to stop the file from being overwritten and begin the installation, all apps in the app center disappear including PHP, upon reconnecting I am left with "Unknown error" under the PHP tile.
Any ideas on what to do next @Mijzelf ? Mizjelf
  • suisei
    suisei Posts: 120 image  Ally Member
    First Comment First Answer Friend Collector Second Anniversary
    You can try with SFTP to do the upload and download
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    @lee626 I don't think your first issue is a problem, as long as the contents of ZYPKGS is stored. I don't think the package manager cares about permissions or timestamp for that file. But you can solve the problem by logging in as root, not admin.
    About issue 2, have you tried without disconnecting?
