PHP-MySQL-phpMyAdmin stuck at 45%
I've fixed the missing apps on my NAS520 thanks to Mijzelf, however when I try to install PHP it gets stuck at 45%. When trying to apply the solution of editing the ZYPKGS file through WinSCP I am met with the following issues.
2. Secondly when I try to disconnect from the internet to stop the file from being overwritten and begin the installation, all apps in the app center disappear including PHP, upon reconnecting I am left with "Unknown error" under the PHP tile.
Any ideas on what to do next @Mijzelf ? Mizjelf
You can try with SFTP to do the upload and download
@lee626 I don't think your first issue is a problem, as long as the contents of ZYPKGS is stored. I don't think the package manager cares about permissions or timestamp for that file. But you can solve the problem by logging in as root, not admin.
About issue 2, have you tried without disconnecting?
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
