NWA50AX to extend my existing WLAN
Hi @Patty97
To connect to the same WiFi name (SSID) when you go to other rooms in your place, you need to set up a WiFi that meets these criteria between the configuration of NWA50AX and your existing WLAN (your modem/router/other access points):
- Same SSID name
- Same security method and same password
Please see this FAQ to follow the steps of how to set it up on Nebula:
Nami
Hi @Patty97
- Same SSID name
Nami
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
