Problem with low download and upload speed with wifi 6 NWA55AXE - 1 Gb contract
Please help because I am lost!
I have a 1Gb fiber contract, fritz box 7530 and a NWA55AXE wifi 6 router, Zyxel POE switch and besides this I have a new laptop with a 1Gb wifi 6 card inside. I measured around 750 Mbps when I connect my laptop with an ethernet cable to the POE switch and Fritz box. When connecting wireless at 1m distance with the NWA55AXE I have around 200 Mbps, how is this possible?
I checked/changed several things > other channel, bandwith etc and it all does not change anything. I had the same problem with the NAP203, but now I have disconnected everything, just connected the NWA55AXE to the POE switch.
I think there is somewhere one or more settings in Nebula (non paid version I have) that is limiting the download, but I checked > SSID has unlimited up/download… and cannot find any. There are a lot of settings, but what I checked/changed did not improve it at all. In my laptop I have a Realtek RTL8852AE WiFi 6 802.11ax PCIe Adapter. I am using prefab/high end cables.
Am I the only one, thanks in advance,
Hope someone can help me!
Best, Ronald
Hi @rwring
There are several factors that can affect WiFi performance. To optimize your NWA55AXE's WiFi performance, please refer to the following guides:
- How to improve slow internet speed on outdoor devices managed from Nebula? — Zyxel Community
- How to Optimize Wi-Fi Connectivity with Nebula AP? — Zyxel Community
Additionally, here are a few tips you might find helpful:
- Ensure your AP's firmware is up to date.
- Verify that your laptop's WiFi drivers are the latest version.
- Double-check that your AP is configured to use the optimal channels and bandwidth settings.
- Consider the positioning of your AP and minimize potential sources of interference.
Kay
Hi @rwring
Kay
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
