LTE5398-M904 - Disconnection under Iliad Operator
Hi There
My Router has more disconnection ( LINK UP, NO TRAFFIC ) with Italian ILIAD Operator.
Many users has got this issue.
Are there some workaround to fix it ?
Last firmware doesn't fix this issue.
Waiting from some good news.
Cheers
Andrea
What is your module firmware version?
You may check it on Cellular WAN Status (Monitor > Cellular WAN Status).
Regards,
Bob
Hi Bob
Here Is It firmware version
EG18EAPAR01A11M4G
My router started doing same in last months. Works 1-2 weeks, then no internet. If i login to router, shows cellular connection is up and ok. Only router restart will fix it.
I have latest firmware:
Modem firmware: EG18EAPAR01A12M4G
Router firmware: V1.00(ABQV.4)C0
I also have static cellular IP, so it's not relayed to wan ip refreshing.
I disabled(currently use separate wifi AP) 2.4G and 5G wifi, seems to work ok after it.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
