NAS326 after firmware update SSH works HTTP does not, phone APP HTTPS doesn't work either.
laz954
laz954 Posts: 1 image  Freshman Member
edited March 2020 in Personal Cloud Storage
I saw many messages about clearing cache, etc. This is not the issue, it looks like HTTPS was disabled after firmware upgrade, SSH is functional with admin/password but HTTPS is being rejected. Phone APP also rejects HTTPS login, can you ssh to the device and enable HTTPS functionality or is there another workaround using SSH or any other method ?
#NAS_Mar_2020
  • RodaBVB
    RodaBVB Posts: 1 image  Freshman Member
    how to disable ssh with password and enable with public key?
    whenever i try to set with public key, return to authentication with password
  • Sakura_T
    Sakura_T Posts: 101 image  Ally Member
    As far as I know, Zyxel NAS doesn't support public key for SSH.
  • just42na
    just42na Posts: 1 image  Freshman Member
    Hey,
    It is possible to make an SSH connection using a public key. You need to have prepared or created your SSH public and private credentials. Connect to your NAS using the root account and password (your admin password) and go to the /root directory. Here you should see the .ssh hidden folder. Go to it, and if it isn't there, you may create an authorized_keys file. Store your public key there.
    After that, check the authorized_keys file; it needs to have 600 permissions. Here we are trying to connect to your NAS using a private key. However, I didn't find a way to deactivate password mode authentication.
    Be careful. This NAS is out of date, so there are no security updates, and it has a lot of issues. Make sure your SSH connection isn't permitted from WAN, only from your local network.
