Port forwarding - I can't get it to work - FW510 in nebula
coupas
coupas Posts: 6 image  Freshman Member
I have a FW510 - it is set up in Nebula:
I don't have a physical firewall as you can see.
However, I tried this:
Didnt work. The port stay closed.
So I tried from the FW510 itself:
2024-07-30 00_03_11-.__Welcome to the Web-Based Configurator__. — Mozilla Firefox.png
But the port stays closed.
What am I missing?
Thanks in advance!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,587 image  Zyxel Employee
    Hi @coupas,
    We found that the reason you cannot successfully use the port forwarding function is that your ISP uses a CGNAT IP address. The public IP address on Nebula is different from the WAN IP address of your Mobile router. You might need to check with your ISP if it is possible to have a non-CGNAT IP address.
    Zyxel Melen
  • Zyxel_Melen
    edited July 2024
    Hi @coupas,
    The NAT rule in the firewall configuration page won't be applied to your Mobile router.
    The NAT rule you set on the mobile router seems no problem. Could you enable Zyxel support access so we can check? I will DM you to request some details to check.
    Zyxel Melen
  • Zyxel_Melen
    Hi @coupas,
    Zyxel Melen
  • coupas
    I see, thanks very much!
  • coupas
    Update:
    ISP gave me a non-CGNAT-adress. And now I have some functionality.
    However, there still are some problems that I cant seem to figure out:
    NAT-loopback seem to to be needed for me to test wan-lan things in my environment.
    My servers are reachable from my network: 192.168.1.4:2283 for Immich for example. But when I try going for the external ip: coupas.se:2283 I can only reach that when I am outside my own network, via VPN. (not real url, just an example)
    How can I enable NAT loopback in FW510?
Nebula Tips & Tricks
