Ap goes on and off several times.
my mesh network goes on and off.
I don’t understand why this is happening. I have not changed anything.
my account is tomas.salzmann@telia.com and you have access.
please give me som help
I have three nwa 130 and mobile router 5101
Best regards
Hi @saltet ,
After reviewing your site settings, we recommend the following adjustments:
- Fine-tune the deployment of root and repeater location. APs must be deployed in the signal covered area (recommended –70dBm or above) while uplink AP is within line-of-sight of repeater. As of now, one AP's uplink signal is about -80dBm.
- Change the radio setting. The path: Configure > Access points > Radio settings.
Adjust the
channel widthto 20MHz for each radio to reduce co-channel interference.Disable
Avoid 5G DFS channelto prevent channel interference.Please monitor the repeater AP's status and inform us of any updates.
Zyxel_Judy
Hi @saltet ,
Adjust the
Zyxel_Judy
Thanks for the recommendations.
i have adjusted the bandwith and DFS.
The deployment will be done soon.
The three ap are in a house which is 26 m long. The distance between root and vind are about 20 meter but with concrete walls but with open doors between the rooms.
I can see on the map in Nebula that it looks like the coverage are low or -80 dbm.
This ap,s seems to be very sensitive to concrete walls.
I will move the root ap together with the 5101 to the middle room and hopefully will the coverage be better.
My second network which I have in another place are not so sensitive as my new 130 ap.0 -
I have now change the deployment.
The coverage became much better.
But the problem ocurrred after the latest update of firmware.
before the update I did not have any problem.
any how.
now it looks good. Even on 6 GHz
Thanks for your help.0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
