Zyxel USG110 access VLAN Config
I have a Zyxel USG110 and an HP 1810 managed switch. I want to create two VLANs on port 5 of the Zyxel, which is directly connected to the HP managed switch. I intend to set up the two VLANs as access VLANs on the HP switch with the following configuration:
- Port 1 in WAN
- Ports 2 and 3 in VLAN 20
- Ports 5, 6, 7, and 8 in VLAN 30
In the HP 1810 switch, should I configure the ports as tagged, untagged, or excluded?
Thank you for your assistance!
Port 1 PVID 1
For VLAN 20 port 1 tag ports 2 and 3 untag with PVID 20
For VLAN 30 port 1 tag ports 5,6,7 and 8 untag with PVID 30
If one of ports 2, 3, 5, 6, 7, and 8 is not connected with a client but a VLAN-aware network device, you should set tag for the related VLAN.
Zyxel Melen0 -
For VLAN 20, I have to untag ports 2 and 3 and tag port 1?
For VLAN 30, I have to untag ports 5, 6, 7 and 8 and tag port 1?
Is that what you mean?
yes and set the
PVID to 20 on ports 2 and 3
PVID to 30 on ports 5, 6, 7 and 8
you should set for VLAN 20 for ports 5, 6, 7 and 8 excluded/forbidden
and set for VLAN 30 for ports 2 and 3 excluded/forbidden
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
