Access a service with username and password
PeterHer
PeterHer Posts: 21 image  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Security
Hi All,
Let's say I have a website running on my server at port 80. I added this service in Network - NAT and added a new rule in Policy Control for this service and a particular user.
The user accesses the website like: www.xxxxx.com, but how to pass an username and password so that only this particular user can access the website?
Thanks in advance.
Peter
  • zyman2008
    zyman2008 Posts: 243 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    It's two step.
    First, login to your USG https://xxx.xxx.xxx.xxx with the username & password.
    You will get a login session page. Keep it open so that USG know the source IP address is bind to this username.
    Then, open another new tab or new windows on browser to access the website behind USG.
  • PeterHer
    Thanks for your reply.
    I have made some changes in the past so the USG210 is only accessible within a local network.
    Cannot figure out what I did, so a user cannot logon through internet.
    SYSTEM - WWW - HTTPS is set to 443 and is enabled.
    SYSTEM - WWW - HTTP is set to 8090 and is enabled.
    Cannot access the USG210 with http://xxx.xxx.xxx.xxx:8090 or https://xxx.xxx.xxx.xxx from a remote location.
    Anything else I should set?
