Port forwarding - I can't get it to work - FW510 in nebula
Hi @coupas,
We found that the reason you cannot successfully use the port forwarding function is that your ISP uses a CGNAT IP address. The public IP address on Nebula is different from the WAN IP address of your Mobile router. You might need to check with your ISP if it is possible to have a non-CGNAT IP address.
Zyxel Melen0
Hi @coupas,
The NAT rule in the firewall configuration page won't be applied to your Mobile router.
The NAT rule you set on the mobile router seems no problem. Could you enable Zyxel support access so we can check? I will DM you to request some details to check.
Zyxel Melen0 -
Hi @coupas,
Zyxel Melen0 -
I see, thanks very much!
Update:
ISP gave me a non-CGNAT-adress. And now I have some functionality.
However, there still are some problems that I cant seem to figure out:
NAT-loopback seem to to be needed for me to test wan-lan things in my environment.
My servers are reachable from my network: 192.168.1.4:2283 for Immich for example. But when I try going for the external ip: coupas.se:2283 I can only reach that when I am outside my own network, via VPN. (not real url, just an example)
How can I enable NAT loopback in FW510?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
