I now have 2 NWA130BE APs and 1 NWA50AX-Pro
Well because if i change the setting to Multicast to unicast my Garage doors and Cameras don't stay connected. Its not specific to my current AP's because it started happening while using my previous NWA210AX APs as well.
Setting Fixed Multicast to 12mbps and Unchecking the boxes for AMPDU and AMSDU also help.
At the moment my download and upload speed on 2.4ghz is 60/60mbps.
- Hi @jpblanch75 .
Thank you for your response.
As mentioned in our initial response, the logs indicate that the disconnection issue with your IoT devices stems from the devices themselves. They continue to send association requests to the AP even when they are already connected, causing them to disconnect and reconnect. This is a behavior of the IoT devices, and the AP is not responsible for kicking them out.
We are more than happy to assist you in checking this issue. To proceed, we really need a wireless packet capture to analyze further what is happening between the AP and your IoT devices.
Please share the wireless packet capture along with the MAC address of the problematic IoT device and the time the issue occurs.
If your time is limited and you are unable to provide this information, you can continue using your current configuration as it appears to help with the issue.
Zyxel_Judy
Its not a specific device. It's anything on the 2.4 network.
Pinging google.com while my laptop is connected to 2.4G SSID
SAME on 5G!
Hi there,
There are several factors that could cause the ping google.com results shown in your screenshot. However, based on the ping google.com results alone, we cannot investigate the issue related to your client disconnecting from the AP and the communication between the wireless client and the AP.
To allow the issue to proceed, please follow the steps provided in our previous comment and share the wireless packet information.
Thank you for your cooperation.
Zyxel_Judy
Well, latest firmware update seems to have taken care of the issue. A bit more time and I'll know for sure.
Seems like someone in engineering knew about the issue. No thanks from here though.
I can't can 't seem to resolve this issue. I've Ivtr8ed every setting. All devices either has micro disconnections or it just won't pass data but stay connected. My 2.4 utilization is very high as well. It's not about my neighbors.
maybe I have a devices on the 2.4 band causing this. That will be a tough find.
It appears that I may have fixed my issue. So far I believe I had a device causing the failure. Been running Ping Plotter for an hour now and not dropped packets.
Well, it appears I spoke too soon. Its funny because right after I unplugged it, I
disconnected because of reason 8.
this happens even when it's the only device on the access point. Roaming is disabled. Multiple devices doing this
Hi users,
The reason 8 is "Disassociated because sending STA is leaving (or has left) BSS". This reason is sending by a client when leaving the AP, and then AP will show this log.
You can refer more reason code definition as below link:
Zyxel_Judy
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 343 Security Ideas
- 295 Service & License
- 471 News and Release
