LITE60 and wifi mesh with NWA50AX PRO suddenly interrupted
2»
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @GiuseppeR,
    This is more likely your APs were using 5 GHz to connect mesh, but due to the poor connection quality, they changed to use 2.4 GHz to connect mesh. Therefore, the 2.4 GHz channel will be the same channel.
    In addition, although the APs will change back to 5 GHz if the connection quality is back to normal, the 2.4 GHz channel will not change to different channels.
    Zyxel Melen
Nebula Tips & Tricks
