LITE60 and wifi mesh with NWA50AX PRO suddenly interrupted
GiuseppeR
GiuseppeR Posts: 782
image  Guru Member
Hello everyone,
I installed a LITE60 with 2x NWA50AX PRO.
LITE60 is the root, both APs are via wifi mesh.
Suddenly one of them goes crazy:
Right now one AP is unreachable.
«1
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,223
    image  Zyxel Employee
    Hi @GiuseppeR,
    Please help to enable Zyxel support. I want to check the AP's event log first to investigate this issue.
    By the way, are the APs connected to LITE60 with cable? or with wifi mesh?
    Zyxel Melen
  • GiuseppeR
    image  Guru Member
    Hello @Zyxel_Melen
    Zyxel support is invited with full priviledges, both the APs are linked wirelessly to LITE60 as root.
    You have a ticket open with that Company, Case 240701015
    Have a nice day, best regards.
  • Zyxel_Melen
    Hi @GiuseppeR,
    After checking, the issue is more likely the signal strength of your AP being too low causing your AP not to connect to the mesh root (LITE 60) stably.
    To fix this issue, please refer to the following FAQ:
    Hope it helps.
    Zyxel Melen
  • GiuseppeR
    image  Guru Member
    edited July 2024
    Hello @Zyxel_Melen
    I'm trying the new config.
    I see no reference to "channel deployment". Is it correct as seen in this photo?
    I'm asking this because the default option for 2.4 is Three-Channel Deplyment, so I'm wondering if it has to be modified accordingly to your screenshots in your guide.
  • Zyxel_Melen
    Hi @GiuseppeR,
    By default, the three-channel deployment on 2.4GHz is chosen, using channels 1, 6, and 11, which minimizes channel interference as these channels don't overlap significantly.
    However, in some environments, channels 1, 6, and 11 may be congested due to other devices like Bluetooth and microwaves. If you experience connection issues, switching the channel deployment to "all available channels" can allow the AP to automatically select the best channel, improving connection quality.
    Zyxel Melen
  • GiuseppeR
    image  Guru Member
    Hello @Zyxel_Melen
    I tried some configs based on your guide, on another Company where I have 3 APs.
    FYI if I limit the channels' width I see a third of the below rate:
    Maybe more stable but less bandwith.
    With the config of 20 MHz for 2.4 and 80 Mhz for 5 radioband the average lag is 10 ms from the far away wifi laptop to main cabled server.
    Is it possible to adjust the channel width dinamically? I mean, an automatic choice made by each AP to choose what to use accordingly to the radio channel traffic used in a specific moment?
    Using Site-wide > Configure > Access points > Radio settings forces each single AP to follow the scheme without optimizing dinamically the environment
  • Zyxel_Melen
    Hi @GiuseppeR,
    To adjust the channel width dynamically, you can change the Adaptive Channel width option in Menu > Monitor > Access points > Wireless health. This function allows you to enable auto optimization to take actions by DCS or changing channel bandwidth to improve wireless network if poor state has been detected.
    For more details, please reference this link.
    Hope it helps.
    Zyxel Melen
  • GiuseppeR
    image  Guru Member
    edited July 2024
    Hi @Zyxel_Melen
    unfortunately not, I have deployed unsupported models:
    A part from that, it seems strange to me that APs do not work at least in different channels:
    You can see 2.4 GHz both in channel 6 and 5 GHz in channel 48.
    Using different channels would reduce interferences.
    The installation is in the country, so good availability of radio channels.
    As you can see I have APs that uses different radios in another mesh installation:
    Is that channel choice limited by the hardware radios?
  • Zyxel_Melen
    Hi @GiuseppeR,
    Can I say the question is wondering why the APs in the first site did not select different channels?
    Zyxel Melen
  • GiuseppeR
    image  Guru Member
    Hi @Zyxel_Melen
    yes, sometimes it seems strange to me understanding the logic behind the choices made by APs.
    Different behavious in (apparently) similar conditions.
Nebula Tips & Tricks
