nsa310 and nsa235-V2 admin doesn't have write access to admin share folders
Dears, have you got any update on this? I too got stuck with the same issue: entware Samba replacement has been working for some time and then… this:
~ # smbstatus -s /opt/etc/samba/ZyXELSambaReplacement.confERROR: invalid DOS charset: 'dos charset' must not be UTF8, using (default value) ASCII instead.Can't open sessionid.tdb
It seems we're not the only ones to have gotten into this:
Moreover, it seems I have some trouble with permissions…
~ # /var/log/samba # cat log.nmbdsh: /var/log/samba: Permission denied
I tried to remove and reinstall samba replacement but got this (seems related)
~ # /opt/etc/init.d/S08samba stopsh: /opt/etc/init.d/S08samba: Permission denied
It's probably related to some mistake I made, but I tried to follow the instructions as they were written - at the best of my understanding 😅
BTW: NFS exports work just fine on Linux.
This might be the solution:
https://community.zyxel.com/en/discussion/comment/67034/#Comment_67034
- 441 Beta Program
- 293 Service & License
