EX3301-T0 With weird short on antenna connector
Leonce
in Home Router
I wanted to install a better antenna and desoldered the pcb antenna that comes with the router to install a pigtail witha rpsma connector. The thing is I see the shield it is shorted with the central pin. Is this ok?? WJ5 connector point.
It is recommended that you do not change any hardware to avoid damage to the device or other problems.
Hi @Leonce
It is at your own risk that you change this part, and I do not work for Zyxel.
Looking carefully at your image of WJ5, they look like should not be shorted together. I think that I would make sure that they are not shorted together with solder. The centre looks like it should be an island…
Kind regards,
Tony
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
