EX3301-T0 With weird short on antenna connector
I wanted to install a better antenna and desoldered the pcb antenna that comes with the router to install a pigtail witha rpsma connector. The thing is I see the shield it is shorted with the central pin. Is this ok?? WJ5 connector point.
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    It is recommended that you do not change any hardware to avoid damage to the device or other problems.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Leonce
    It is at your own risk that you change this part, and I do not work for Zyxel.
    Looking carefully at your image of WJ5, they look like should not be shorted together. I think that I would make sure that they are not shorted together with solder. The centre looks like it should be an island…
    Kind regards,
    Tony
