FWA510 changes from 1000M to 100M after few days usage
dragondeth
I'm having some issues with my FWA510 and and can't understand why. After a few days it changes from 1000M to 100M and the only way to fix that is to factory reset my router. Before, all I had to do was change the cable from LAN1 to LAN2 port and that usually fixed it. But after few weeks that doesn't seem to fix it anymore. So now all I can do to fix it is to factory reset the router.
Is there a way to manually set the speed to 1000M (I remember I had a D-Link router before that could do just that).
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
