[XGS1930] Full CLI access?
MichaelB
MichaelB Posts: 6 image  Freshman Member
edited August 2022 in Switch
I´d like to get full CLI access on my XGS1930 switch with firmware V4.70(ABHS.1) and local management. Currently if I log with my admin credentials I can only e.g. "show running", but I´m not able to change anything, e.g. "configure terminal" is no possible.
I searched the GUI but haven´t found anything usefull. Is it even possible?
Regards
Best Answers
  • Zyxel_Albert
    Zyxel_Albert Posts: 36 image  Zyxel Employee
    First Answer First Comment Friend Collector Third Anniversary
    edited May 2021 Answer ✓
    Hi @MichaelB
    XGS1930 is a web-managed switch. It only supports web configuration.
    The CLI only allow you to use the "show" command to check switch statistics and table, like: show running-config, show mac address-table all, show interfaces status, etc...
    Reminder: You may use "show ?" to display all commands which can be use with show.
    Regards
  • eddeig
    eddeig Posts: 9 image  Freshman Member
    I still have a XGS1930 in use. What would you suggest, if I want a new switch with about the same capabilities as the old XGS1930, but WITH full CLI capability?
    Regards,
    Eddeig
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,153 image  Zyxel Employee
    Hi @eddeig,
    Since you need full CLI capability, you may consider the XGS2220 series.
    For more information, please reference our website.
    XGS2220 Series - 24/48-port GbE L3 Access Switch with 6 10G Uplink - Overview | Zyxel Networks
    Zyxel Melen
  • eddeig
    Since we have no full CLI on XGS1930, is there some way to speed up setting up "Time Ranges"?
    So far I have to set each port separate which takes a lot of tome if you have to configure multiple ports.
    Kind regards,
    Eddeig
  • eddeig
    By the way… Your datasheet is STILL misleading! See for yourself:
    https://download.zyxel.com/XGS1930-28HP/datasheet/XGS1930-28HP_6.pdf
    It says "Management through Telnet" - you should mention that you do not have full CLI management via Telnet!
    Regards,
    Eddeig
  • Zyxel_Melen
    Hi @eddeig,
    You can consider using Nebula mode. The Nebula control center allows you to select multiple ports and configure the same PoE schedule.
    Thanks for your input. Please be assured that I will let our switch product team know your input. In addition, the web-managed switches do not support full CLI. They only support monitoring commands.
    Zyxel Melen
