USG Flex100 - Is it possible to know what its CPU is processing?
GiuseppeR
GiuseppeR Posts: 664 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited September 2024 in Nebula
Hello everyone,
I have some Flex100s on production, but I have a specific site for a healthcare company where I see high usage (to be clear, it happens more often than other sites) compared to generated traffic:
As you can see the usage is about 31% and it seems strange due to the fact it is a small network with about 20 clients and no outgoing traffic (see wan1 Utilization).
So my question is what the firewall is processing, is it possible to see what it is doing via Nebula?
Maybe some threats? Some ADPs? Some IDPs?
Best Answers
  • Zyxel_Kay
    edited September 2024 Answer ✓
    Hi @GiuseppeR
    There are several factors that can affect CPU usage, and a usage level of around 54% is generally not considered high. To check the current CPU status of your firewall, you can connect via SSH and use the following commands:
    show cpu all
    show cpu status
    show cpu average
    debug system ps
    If you need further assistance, you can enable Zyxel Support and provide us with your organization and site name. We can then remotely access your site via SSH and investigate further.
    Additionally, to maintain optimal performance, ensure your firewall is running the latest firmware. The current version for the USG FLEX 100 is V5.39.
    Kay
  • Zyxel_Kay
    Hi @GiuseppeR
    As discussed via email, you encountered difficulties with the firmware upgrade due to insufficient memory space on the device. After rebooting, you successfully upgraded to the latest firmware version.
    Please monitor the CPU usage and let us know if you notice any abnormal behavior. If you need further assistance, don’t hesitate to reach out again.
    Kay
  • GiuseppeR
    A quick update, after 15 mins from the opening of this thread:
    I just refreshed the webpage on Nebula.
  • GiuseppeR
    After some hours, same Company in this moment:
  • Zyxel_Kay
    Hi @GiuseppeR
    show cpu all
    show cpu status
    show cpu average
    debug system ps
    Kay
  • Zyxel_Kay
    Hi @GiuseppeR
    Kay
Nebula Tips & Tricks
