How to find USB share in Windows10.
Zyxel_Support_CPE
If you want to access a hard drive or flash drive to USB on the router, but the connection isn’t successful when using the system win10. Please try to enable the SMB1.0 in the win10 first.
Step 1: Go to the Win10 Control Panel to set the SMB1.0 Feature- Control Panel -> All Control Panel Items
-> Programs and Feature
- Click “Turn Windows features on or off”.
- Enable “SMB 1.0/CIFS File Sharing Support”
Step 2: Go to Windows Start and then search “network” programs. After find it, double click “netowork”
If lan IP of your device is 192.168.1.1, please type \\192.168.1.1 as followings. Then type username/password if it’s need.
After that, access to the drive is successful.
Ik heber een harde schijf van 5TB aan gehangen , deze accepteerd hij .alles is te openen of te bekijken met windows 10 explorer en via o.a. KODI af te spelen
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
