NR5101 latest firmware upgrade and Module Upgrade
CharlesfromFrance
CharlesfromFrance Posts: 3  Freshman Member
Hello Folks,
I have done a firmware upgrade on my NR5101.
I have done it through the Online Firmware Upgrade to following Firmware : V1.00(ABVC.9)C2.
So far so good. However It does not seems to be latest recommended.
Can you confirm if I should rolled back to ABVC.6C0 or keep the ABVC.9C2 ?
Also my module firmware is RG502QEAAAR11A03M4G.
Should I upgrade it ? where can I find the latest one ?
Many thanks
  • Friday
    Friday Posts: 110  Ally Member
    Hi @CharlesfromFrance ,
    Can you confirm if there's any issue encounter using V1.00(ABVC.9)C2?
    you mentioned so far so good but it does not seem to be latest recommended.
    thank you.
  • CharlesfromFrance
    Hi Friday,
    I do not have any issue.
    As the automated upgrade was proposing the ABVC.9 fmw.
    I assumed it was tested and rock solid.
    So I moved to the ABVC.9.
    Then I have seen the post where the last recommended firmware is ABVC.6C0.
    I do not know If I should revert to ABVC.6C0. I do not have any issue with the ABVC.9C2.
    Many thanks
  • Jeanbon
    Jeanbon Posts: 1  Freshman Member
    where did you find this firmware ? any link to share ? Thanks in advance
  • Zorrobazz
    Zorrobazz Posts: 3  Freshman Member
    Where can we DL this Firmware from??? Links anyone?
    Firmware Version
    Firmware Release Date
    Firmware Size
    V1.00(ABVC.9)D0
    2024-07-11
    20108778
