NR5101 latest firmware upgrade and Module Upgrade
Hello Folks,
I have done a firmware upgrade on my NR5101.
I have done it through the Online Firmware Upgrade to following Firmware : V1.00(ABVC.9)C2.
So far so good. However It does not seems to be latest recommended.
Can you confirm if I should rolled back to ABVC.6C0 or keep the ABVC.9C2 ?
Also my module firmware is RG502QEAAAR11A03M4G.
Should I upgrade it ? where can I find the latest one ?
Many thanks
Hi @CharlesfromFrance ,
Can you confirm if there's any issue encounter using V1.00(ABVC.9)C2?
you mentioned so far so good but it does not seem to be latest recommended.
thank you.
Hi Friday,
I do not have any issue.
As the automated upgrade was proposing the ABVC.9 fmw.
I assumed it was tested and rock solid.
So I moved to the ABVC.9.Then I have seen the post where the last recommended firmware is ABVC.6C0.
I do not know If I should revert to ABVC.6C0. I do not have any issue with the ABVC.9C2.
Many thanks
where did you find this firmware ? any link to share ? Thanks in advance
Where can we DL this Firmware from??? Links anyone?
Firmware Version
Firmware Release Date
Firmware Size
V1.00(ABVC.9)D0
2024-07-11
20108778
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
