NR7103 supervisor/root password
Andy777
Hi, I would like to request the default root or supervisor password so I can login to my FWA router directly over ssh.
Model = NR7103
S/N = S220Z27000240
Hello, did you get any solution? Thanks
I did not.
But upon further investigation I discovered that the NR7103 doesn't support a connection over SSH.
The EX3301-T0 does, but I don't know if going through it would allow you to setup iptables for the NR7103, which is what I want to achieve by logging in with root/supervisor pwd.
I think normally they will not release the root PW for user. Or can you say what kind of function you want to achieve?
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
