NR7101 massive problems
Hi, hope you all are fine?
I have NR7101 LTE router, and it worked fine for about one year. Now I am really struggling with this device.
When I make a speedtest the connections drops, and it looks like the device is restarting again. I think the router is a branded device (Austria A1) I somehow could upgrade the firmware to 1.00(ABUV.8)C0, but I have no idea how to upgrade the modem firmware. At the moment it shows the firmware RG502QEAACR13A04M4G_ZYXEL. I have no idea how to upgrade this firmware.
Anyone has an idea, that can work. I tried several files, but always got the message that it is an illegal image ;( Can ynyone tell me whith witch image (exact name of the image) I should start.
Could it be that there is a hardware problem with my router. How long is warranty on such a device?
Would be very happy, if someone can help me.
Regards. Arthur
Does the reboot only happen you do the speedtest? Besides reboot, does everything work fine?
Where did you buy the device? If you buy it from the ISP (A1 Austria), you can ask ISP for help.
AFAIK this RG502QEAACR13A04M4G_ZYXEL is latest modem for NR7101 provided by Zyxel (although not really provided anywhere really)
Start checking with A1 if they can see cause of connection drop outs
Hi and thanks for the reply. Can it be that this LTE firmware causes the problems?
Would it be possible to upload another firmware, which is well known for working?
Updated the router no to
1.00(ABUV.10)C0
but still the same. If I start speedtest connection breaks down and It looks like the device is restarting.
Regards
Arthur
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
