NAS540 - File Restore Fails
Hi hope someone can help. If I delete a file using NAS File Browser, the restore function fails. Have tested on various folders, re-enabled recycle, rebooted etc.
Any ideas? Can someone confirms this works for them - FW is V5.21(AATB.13)
The recycle bin should function on the device. You can double-check if a file has been deleted by accessing it with File Explorer on Windows or using SSH to verify if the file is truly gone.
It’s possible that caching could be causing the issue, so please confirm whether the file has been deleted and check for any similarly named files in both the recycle bin and the original browser.
Hi, thanks. The files is 100% deleted in each case, SSH checked.
No duplicate files in recycle.
When you refer to cache - is this browser or cache on in the O/S?
Have tested on multile files in multiple folders, same result.
Thanks for your interest - appreciated
If you have a backup, consider resetting the NAS to see if the issue persists. Alternatively, you can copy the files from the recycle bin using SSH. :)
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 516 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
